HTTP request failed: AttributeError
It may be a quick fix but I've not been able to resolve this issue for a week and need help.
When I try to use my APP key to connect Python and Refinitiv, I have started getting this error message recently. All my students are getting this error too:
"HTTP request failed: AttributeError-'NoneType' object has no attribute 'http_request'
I have checked prior posts but haven't found a solution. Help will be appreciated.
18k 21 12 20
Hi @cafriyie
This is a generic answer to your issue.
- Try upgrading the Eikon Data API to the latest version using pip install --upgrade eikon command
- Try upgrading Eikon Desktop to the latest version
- Reboot your computer and try again.
- Follow this troubleshooting guide.
- Enable log on API
import eikon as ek
ek.set_log_level(1)
ek.set_app_key('<a valid appkey>')
If it still does not help, collect the log file (following troubleshooting guide) then submit a ticket to Refinitiv Helpdesk.
The Refinitiv Helpdesk can be reached using Contact Us capability in your Eikon application.
