I am using the below codes for event dispatch, where EVENT_TIMEOUT_PERIOD = 0
I found that only 350-400 events can be dispatched every second, is there any configuration I can set to increase the throttle rate?
(if there are messages in the queue, 350-400 events will be dispatched every second,
if there is no message in the queue, it will loop about 100000 times every second)
void dispatchEvent()
long dispatchReturn = simpleConsumer.getEventQueue()->dispatch(EVENT_TIMEOUT_PERIOD);
I tried to apply the following configuration but it doesnt work
\Connections\Connection_RSSL\watchListTableSize = 100001 \Connections\Connection_RSSL\guaranteedOutputBuffers = 1000
\Connections\Connection_RSSL\numInputBuffers = 1000
\Connections\Connection_RSSL\throttleEnabled = true
\Connections\Connection_RSSL\throttleType = "count"
\Connections\Connection_RSSL\throttleBatchCount = 500
\Connections\Connection_RSSL\throttleMaxCount = 1000
\Sessions\Session1\connectionList = "Connection_RSSL"
\Sessions\Session1\threadModel = "Dual"
