SEQ-case-ogs-enable: Enable ongoing screening for a case - using this api we can enable only one case at once.
Is there api for enable ongoing screening for bulk cases?
thank you
thank you
Enabling multiple cases for Ongoing Screening is currently not available. Only one case can be enabled at once using API as of now.
You may use asynchronous screening approach in order to save and screen multiple names in 1 API call. Using this approach, you may be able to enable ongoing screening for the cases (up to 50 cases) in the same API call. Below is the snippet payload -
Endpoint - /cases/saveAndScreen
{ "groupId": "{ {group-id}}", "providerTypes": [ "WATCHLIST" ], "nameTransposition": false, "caseScreeningState": { "WATCHLIST": "ONGOING" }, "cases": [ { "entityType": "ORGANISATION", "name": "SmithCorporation" }, { "entityType": "INDIVIDUAL", "name": "John Smith" } ] }
SEQ-case-monitor-ogs: Monitor ongoing screening updates on cases - i can get updated result from this api like this,
now i want get updated values with fields it means new results, which api can i use for it
In order to check the details due to ongoing screening, you will have to do the following -
1. Fetching screening results (/cases/caseSystemI/results): You would have to fetch the case results using the caseSystemId of the case and check the following -
2. Fetch the specific profile (reference/profile/profile-Id): Once you have identified the match which has been update, you may fetch the profile information of the match to check for further details.
Please do let us know if you need further clarifications.
HI,
i have developed OGS. i have no data to test it. is there any test data to check this api SEQ-case-monitor-ogs: Monitor ongoing screening updates on cases?
Below is the format of the response -
{ "query": "updateDate>='2021-05-21T13:23:44.213Z'", // Query in request payload "sort": null, "totalResultCount": 6, "pagination": { "currentPage": 1, "itemsPerPage": 100, "totalItems": 6 }, "results": [ { "caseSystemId": "5l8v60vvlfcm1evuoul5fv2rt", "updateDate": "2021-05-25T07:14:25.229Z", // Update as on date "numberOfNewResults": 1, // New match in the case due to OGS "numberOfUpdatedResults": 0 }, { "caseSystemId": "5jb6puhku6im1fbp8sin3t1c4", "updateDate": "2021-05-28T07:14:35.600Z", "numberOfNewResults": 0, "numberOfUpdatedResults": 1 // Update on an existing match due to OGS }, { "caseSystemId": "5jb6vbtcst801fokmnrcif936", "updateDate": "2021-05-28T07:51:16.621Z", "numberOfNewResults": 0, "numberOfUpdatedResults": 1 }, { "caseSystemId": "5l8v64txti7j1evuomd6syrcj", "updateDate": "2021-05-25T09:41:43.806Z", "numberOfNewResults": 1, "numberOfUpdatedResults": 0 }, { "caseSystemId": "5jb7gz67ndsg1fj08vj3vxrnx", "updateDate": "2021-05-27T00:57:06.985Z", "numberOfNewResults": 1, "numberOfUpdatedResults": 0 }, { "caseSystemId": "5jb7gz67ndsg1fj08vj3vxrnx", "updateDate": "2021-05-25T22:31:36.059Z", "numberOfNewResults": 0, "numberOfUpdatedResults": 1 } ] }
