How to convert RIC / CUSIP / SEDOL to EstimateID in RDP
I see that EstimatedID is the primary company identifier in the ARM Output file for RDP Starmine. Please advise how can we convert RIC / CUSIP / SEDOL to EstimateID in RDP?
Should we do the conversion in RDP endpoint /discovery/symbology/v1/lookup? If so, may you kindly share the specific request POST parameters that we can use to convert RIC to EstimateID.
rdp-apirefinitiv-data-platformstarmine
Hi @Jenna.Tabunda,
I am unable to find estimate ID in symbology conversion. However, you could use search or searchlight for this lookup.
Here is an example for RIC -> estimate ID conversion:
POST https://api.refinitiv.com/discovery/searchlight/v1/
  "View": "SearchAllLight",
  "Filter": "RIC eq 'IBM'",
  "Select": "QuoteEstimateID"
Response:
  "Total": 1,
  "Hits": [
      "QuoteEstimateID": "US_4741N_1"
similarly:
  "Filter": "CUSIP eq '459200101'",
  "Total": 177,
  "Hits": [
