Error code 500 | Server Error
Hi, I am trying to retrieve data from the Eikon Data API, using python (Jupyter Notebook). However, I keep getting the following error:
Error code 500 | Server Error: {"code":500,"message":"self signed certificate in certificate chain","statusMessage":"Internal Server Error"}
My code is as follows:
import eikon as ek
ek.set_app_key("xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx")
ek.get_news_headlines('R:LHAG.DE', date_from='2019-03-06T09:00:00', date_to='2019-03-06T18:00:00')
Other info:
Desktop 4.0.53 (4.0.53072)
Proxy (9.53.0.68)
nest-asyncio 1.5.1
eikon 1.1.10
python 3.8.3
Please let me know what can I do. In the past I was able to retrieve data. I don't know whay now I can't.
Thanks in advance
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonerror-500
1.4k 6 2 2
Hi @bdelavictoria,
Would you mind letting us know if (i) you are able to connect without going through a proxy server and (ii) if not, do you have access to the proxy's certificate (is it 9.53.0.68)? This debugging step comes from this question.
I have similar error, I hope someone can help thx
Hi @admin01,
Similarly, if points (i) and (ii) are different for you, the answer could be different. Have you had a look at this question?
Points (i) and (ii) in question were from the following extract: "would you mind letting us know if (i) you are able to connect without going through a proxy server and (ii) if not, do you have access to the proxy's certificate (is it 9.53.0.68)?"
