How to retrieve ownership data using the Eikon Formula Builder?
Hey there,
I am using the Formula Builder and want to download Ownership variables (“ TR.InvestorFullName;TR.InvestorAddrCity;TR.InvestorRegion;TR.InvestorType;TR.PctOfSharesOutHeld;TR.SharesHeld;TR.HoldingsDate"). However my request runs forever without a result.
I used this formula: =RDP.Data($D$2:$D$914,"TR.InvestorFullName","SDate=2019-12-31 CH=Fd RH=IN",I2)
The range ($D$2:$D$914) includes the companies i want to get the data for. Could you give me some advice why that did not work?
eikoneikon-com-api
I think the problem is likely that you're requesting too much data in a single function. The result set for your request is likely well over a million datapoints. Try retrieving ownership data for a single stock. If you have the same problem retrieving ownership data for a single stock, open a support case with Refinitiv Helpdesk. Refinitiv Helpdesk can be reached by calling the Helpdesk number in your country, using Contact Us capability in your Eikon or Refinitiv Workspace application or by visiting MyRefinitiv.
