RFA 7.7 C++ libRFA_Adapter.so contains absolute path to libTibMsg
I have changed an application that used the older 32bit RFA 6.5 C++ on RedHat Linux to use the current version 7.7. This resulted in a problem with libRFA_Adapter.so trying to open libTibMsg.so from an absolute path outside the RFA installation. The library file does not have an rpath set but it contains the full path as a string:
/opt/rfa/rfa7.7.0.L1.linux.rrg/Libs/RHEL6_32_GCC444 ] strings libRFA_Adapter.so | grep jenkins
/local/jenkins/workspace/RFACPP_762_Core/OS/RH6-32/tapi/prod/x86_Linux_6X/gnu44-o/lib/lib_so/libTibMsg.so
QUESTION:
Can I prevent the RFA_Adapter from trying to open the TibMsg library from that path by configuration or is this behaviour hard coded? In my view, the latter case would mean that Refinitiv should provide a new version without this behaviour. Would you be able to do so?
My current workaround is to create the full path and link the library from the RFA installation directory. I would very much like to avoid this in a later production installation.
Thank you very much in advance for any suggestions.
Kind regards,
Winfried Schleipen
treprfarfa-apic++32-bit
@Winfried1 Schleipen01
You are correct. It could be a problem in RFA 7.7.0.L1.
I have checked RFA 7.6.2.L1 and found that libRFA_Adapter.so doesn't depend on /local/jenkins/workspace/RFACPP_762_Core/OS/RH6-32/tapi/prod/x86_Linux_6X/gnu44-o/lib/lib_so/libTibMsg.so.
[root@localhost RHEL6_32_GCC444]# ldd libRFA_Adapter.so.7
        linux-gate.so.1 =>  (0x00824000)
        libRFA_Config.so => not found
        libRFA_Logger.so => not found
        libRFA_Common.so => not found
        libRFA_Connections.so => not found
        libRFA_Connections_MD.so => not found
        libTibMsg.so => ./libTibMsg.so (0x0072b000)
        libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00893000)
        libm.so.6 => /lib/libm.so.6 (0x0046d000)
        libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00386000)
        libc.so.6 => /lib/libc.so.6 (0x00110000)
        /lib/ld-linux.so.2 (0x009b6000)
While libRFA_Adapter.so in RFA 7.7.0.L1 depends on /local/jenkins/workspace/RFACPP_762_Core/OS/RH6-32/tapi/prod/x86_Linux_6X/gnu44-o/lib/lib_so/libTibMsg.so.
        linux-gate.so.1 =>  (0x00a55000)
        libRFA_Config.so => ./libRFA_Config.so (0x00110000)
        libRFA_Logger.so => ./libRFA_Logger.so (0x00f4d000)
        libRFA_Common.so => ./libRFA_Common.so (0x0015d000)
        libRFA_Connections.so => ./libRFA_Connections.so (0x0052f000)
        libRFA_Connections_MD.so => ./libRFA_Connections_MD.so (0x003a1000)
        libTibMsg.so => ./libTibMsg.so (0x00590000)
        /local/jenkins/workspace/RFACPP_762_Core/OS/RH6-32/tapi/prod/x86_Linux_6X/gnu44-o/lib/lib_so/libTibMsg.so => not found
        libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00721000)
        libm.so.6 => /lib/libm.so.6 (0x00aea000)
        libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x001b2000)
        libc.so.6 => /lib/libc.so.6 (0x001d0000)
        librt.so.1 => /lib/librt.so.1 (0x00360000)
        libpthread.so.0 => /lib/libpthread.so.0 (0x00369000)
Please submit this case to the RDC support team via Contact Premium Support to verify and fix this issue.
Hello, thanks for confirming my findings. I hope that the RDC support team will be able to solve the issue. Until then, my request is unfortunately not solved. But your response was nonetheless helpful for me.
