CodeBook 403 for external connection
In CodeBook I am getting 403 forbidden or 403 max retries reached for any connection, I assuming, outside the server network.
For example, it would be useful to use the Intelligent Tagging API at https://api-eit.refinitiv.com/permid/calais or scrape some information off of a wikipedia page.
I guess these are blocked at the moment. Is it possible to get outside connections unblocked? It would be extremely useful.
The full error message for the tagging API case is:
ProxyError: HTTPSConnectionPool(host='api-eit.refinitiv.com', port=443): Max retries exceeded with url: /permid/calais (Caused by ProxyError('Cannot connect to proxy.', OSError('Tunnel connection failed: 403 Forbidden')))
Edit: Forgot to mention. I've contacted support and they suggested asking here.
intelligent-tagging-apiintelligent-taggingopen-calais-apisemantic-metadata-taggingcodebooknetworkingerror-403
18k 21 12 20
Hi @james123
I have passed your feedback to the CodeBook product manager.
@chavalit.jintamalit Thank you. Does that also mean that I am correct in assuming that the errors I am receiving are due blocked connectivity?
Hi @james123
Yes, you are correct.
Currently, the connection to "https://api-eit.refinitiv.com/permid/calais" is being blocked on the Codebook.
@chavalit.jintamalit Thank you for the clarification. To add to any feedback. It would be extremely useful to have broader internet connectivity available beyond this API.
I have the same message when using the pre-installed yahoo finance ... in CodeBook for Datastream
import pandas as pd
import yfinance as yf
tsla_df = yf.download('TSLA',
                      start='2020-01-01',
                      end='2021-10-30',
                      progress=False)
tsla_df.head()
There is no possibility to set first the "requests" with verify=false to avoid the proxy? Any idea?
