What does Action==7 mean
I'm developing a C# app to work with the REDI API, and I've used your example as a starting point:
https://github.com/Refinitiv-API-Samples/Example.REDI.CSharp.Examples/tree/master/REDIConsoleOrders
When I monitor the CacheControl events that are triggered, I see numerous events with Action == 7:
But this is surprising, since the documentation doesn't describe such an action:
So my question is: What is Action 7? What does it mean? And do you have another document that includes this information? (The document I have is redi_api_specification_6.pdf).
Thanks in advance,
Patrick
redi-apicaching
23k 22 9 14
Hello @patrick.noble,
I would suggest processing in the client code the actions that are documented in REDI spec, and disregarding other actions, which can be seen sometimes, including action=7. They are not intended as actionable for the client code and should be quite infrequent, compared to the actionable.
For completeness, 7 is "about to delete".
REDI Spec is the definitive document on REDI API integration, there is no document that includes the additional information.
