How to get the Quote Currency from a TREP RFA MarketPrice subscription?
I've created a MarketPrice subscription with the RFA feed. I received bid and ask on the REFRESH response but I also require the currency. How do I get this value? thanks.
treprfarfa-api
9.5k 10 5 7
As far as I know, the currency is in Field ID 15 CURRENCY as mentioned in RDMFieldDictionary:
CURRENCY   "CURRENCY"              15  NULL        ENUMERATED    5 ( 3 )  ENUM             2 !
! The currency in which the instrument is quoted.
The example when subscribing the RIC JPY=. It showed the currency is JPY in field id 15
9.5k 10 5 7
@randeep gill
If you have any questions regarding RFA technical issue, please specify RFA edition you use e.g. RFA.NET, RFA C++, RFA Java. Hence, you will get the proper answers.
