How to retrieve trace data using Eikon API
I would like to retrieve trace data using API, how can I do so?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikontrace
18k 21 12 20
Hi @karleng.teo
You can try this code:
df = ek.get_timeseries('88160RAD3=FINR', start_date='2021-04-01', end_date='2021-04-21', interval = 'tas', raw_output=True)
df
Then convert the json to dataframe:
df2 = pd.DataFrame(df['timeseriesData'][0]['dataPoints'])
df2
I could not find the "Conditions" information.
I think the FILTER_CODE2 is used to categorize the Buy/Sell.
But you should clarify the information with Refinitiv Content Helpdesk.
The Refinitiv Content Helpdesk can be reached using Contact Us capability in your Eikon application.
Hi @chavalit.jintamalit, thanks for this.
I've encountered another 404 error when I tried to input the Eikon login details. Could you also share what is the process to link to the Eikon login when trying to retrieve data using API?
Thanks @chavalit.jintamalit
I realised the issue was because I was not using Python. Are there any REST APIs available, or is there any way I can use Java to get the data via API?
Otherwise, please let me know if there's a helpdesk I can call to get more assistance. Thank you.
18k 21 12 20
Hi @karleng.teo
I would like to clarify what the trace data is.
Please provide some screenshots, thanks.
1.4k 6 2 2
Hi @karleng.teo,
By TRACE, do you mean Trade Reporting and Compliance Engine data?
In which case, you can use out Data Item Browser (DIB) to find fields of interests such as "GN_TX20_1", "GEN_TEXT16", "GN_TXT16_2", "GEN_VAL2", "GV1_TEXT", "ROW80_8", "LONGLINK1", "SPREADREF2", "EMAIL_ADRS", "OPTION_XD2", "TOT_ISSUES", "OPTION_XID", "GV5_TEXT", "DSPLY_NME2", "ISSUES_ADV", "ISSUES_DEC", "NEW_HIGHS", "NEW_LOWS", "TRDVOL_1", "ISSUES_UNC", ...
All numbers above can be changed at your convenience.
As an e.g.:
Thanks @chavalit.jintamalit @jonathan.legrand
I am looking at bonds, this is the TRACE data that I am referring to.
