Hi all,
I deploy the API between a SAP System and world check. I use the request get result to recover wo important information: risk level (RiskId) and Status (StatusId). In the JSON file that it sent back to SAP by WC-1, I remark that the RiskID and StatusID are express in code and not wiht the values labels in WC-1.
Is someone have the matrix of the code for each value ?
By the way, I remarked that the codes assoicated to the values RiskID and StatusID change if the Entity Type is changed (Switch to Organisation to Unspecified).
Just below a image of the codes for Entity type = UNSPECIFIED.
Is someone have the matrix of the codes for both Values (Status and risk) by Entity type ?
Are this codes changing ?
Thanks by advance for your feedback.
