Streaming Quotes from RDP
Hi Team,
Kindly advise regarding the following client query on streaming market data via RDP API:
I have started to do some initial analysis on the streaming quotes from RDP using the Python example.
python streamingpricingwealth_market_price_edpgw_authentication.py --user simon.cater1@refinitiv.com --password ******* --clientid 5bb037a279674675adf794ddaaf47cb7a13b115b --hostname amer-2.pricing.streaming.edp.thomsonreuters.com --service ELEKTRON_DD
This was working but has stopped in the last week.
I know get the following:
Connecting to WebSocket wss://amer-2.pricing.streaming.edp.thomsonreuters.com:443/WebSocket ...
[Errno 60] Operation timed out
WebSocket Closed
Can you help?
When it was working I tried to get the CF_LAST value as part of the stream, This was not coming through. Could you let me know why that could be?
Thanks,
Simon Cater <simon.cater@finbourne.com>
rdp-apirefinitiv-data-platformstreaming-prices
Hi Nitesh,
The client is using old sample and endpoint. Please have them use the service discovery sample from here.
They might also have to update the python websocket-client module to the latest version 0.58. If there are any issues, please have them ask a question here directly.
Please note: CF fields are consolidated FIDs they may not be in the ELEKTRON_DD service. For consolidated FIDS you would need the correct licence on the user with the ES_ERT_FD3_LF1 PO in it, this then forces the streaming to the correct service.
23k 22 9 14
Hello @Nitesh Saha,
Please ask client developers to test with example as advised by @Gurpreet, passing in the command line parameter:
--service ERT_FD3_LF1
Please encourage the client developers to register on developers portal, to be able to review the developer materials, and access/search the dev forums for answers and ask the questions directly.
