How to pull organization id using debt ticker code
We are trying to pull organisation id's and company/issuer names from Eikon using the debt ticker code. Is there any function on excel or in the API that would allow us to do so.
For eg: HHYON - Hydro One
GEELYV - Volvo Car AB
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonapiexcelsymbologyissue
18k 21 12 20
Hi @MJarosz
I think this code should work:
Search for result
#pip install refinitiv.dataplatform
import refinitiv.dataplatform as rdp
rdp.open_desktop_session('xxxxxxxx')
df = rdp.search(query="HHYON", top=2000, view = rdp.SearchViews.SearchAll )
df1 = df[df['RIC'].notnull()]
df1.head(5)
Filter for ticker = HHYON
rics = df1['RIC'].tolist()
fields = ['TR.TickerSymbol', 'TR.FiTicker','TICKER', 'GV1_TEXT', 'TR.CDSTicker', 'TR.CDSRefEntTicker', 'TR.TickerSymbolOld', 'TR.IssuerTickerCode', 'TR.TickerSymbolCode']
df2,e = ek.get_data(rics, fields)
df3 = df2[df2['TICKER']=='HHYON']
df3.head()
Hi @chavalit.jintamalit,
Thank you for the answer above. I just have a follow up question of what would go inside open_desktop_session. I have Eikon API Proxy open and I've tried adding in the app key for the eikon data api but rdp.seach result returns None. Am I missing something here?
@MJarosz
In rdp.open_desktop_session you should be able to use the same app key you use in ek.set_app_key method. I also suggest you take a look at the response by @marcin.bunkowski below, as it better answers your use case than the example provided by @chavalit.jintamalit
3.8k 4 4 6
Hi @MJarosz, you can also try:
rdp.search(view = rdp.SearchViews.FixedIncomeQuotes,
filter = "IssuerTicker eq 'HHYON'",
select = "IssuerCommonName,IssuerOAPermID",
top=1)
