KeyError in Python Code
I've linked Refinitiv with Python and wanting to calculate a series of risk adjusted metrics (e.g. returns, std, beta, etc) for a bunch of shares. Relevant section of the codes after linking etc reads as follows:
def rapm(stocks, benchmark, start_date, end_date, RF, MAR):
data = pd.DataFrame()
bench = pd.DataFrame()
data = ek.get_timeseries(stocks, fields ='CLOSE',start_date='2017-01-01', end_date='2020-11-30')
bench = ek.get_timeseries('.FTSE', fields ='CLOSE',start_date='2017-01-01', end_date='2020-11-30')
table = BeautifulTable(maxwidth=120)
for i in stocks:
# Calculation of Daily Returns (Stocks and Benchmark)
data['daily_return_' + i] = data[i].pct_change()
bench['daily_return'] = bench.pct_change()
rapm(['AZN.L','GSK.L','HIK.L','SN.L'],['.FTSE'],'2017-01-01','2020-11-30', 2, 2)
When I run the code, I get the error message:
KeyError: 'daily_return_AZN.L'
Fairly new to using Python and Refinitiv.
Any ideas on how to fix this will be greatly appreciated.
@cafriyie, In your code:
# Calculation of Cumulative Return (Stocks and Benchmark)
st_return_i = np.prod(data['daily_return_' + i] + 1 ) - 1
bench_return = np.prod(bench['daily_return_' + i] + 1) - 1
You are trying to access column daily_return_*** on dataframe bench, but you haven't defined it. In other words, bench['daily_return'] is a valid entity, whereas bench['daily_return_AZN.L'] is not.
For general help with Pandas, it is best to ask question on the Python/Pandas forums on the stackoverflow.
Hi @cafriyie,
There must be some other issue in the code; the snippet you have pasted works ok without error. You will have to attach the complete python code, for us to debug it.
Here is the output I get:
Hi @Gurpreet, Thank you very much for your response. I have uploaded the full set of codes in my post below. If you could have a look for me please? Thank you once again.
Hi @Gurpreet,
Please find below full details of my codes as per your request above:
import pandas as pd
import numpy as np
import pandas_datareader as web
import eikon as ek
import configparser as cp
from beautifultable import BeautifulTable
from scipy import stats
cfg = cp.ConfigParser()
cfg.read('eikon.cfg.txt')
ek.set_app_key(cfg['eikon']['app_id'])
stocks = ['AZN.L','GSK.L','HIK.L','SN.L']
table.columns.headers = ['Stock','Return','Benchmark Return','Standard Deviation','Downside Deviation','Beta',
'Tracking Error','Sharpe Ratio','Sortino Ratio','Treynor Ratio','Information Ratio']
table.set_style(BeautifulTable.STYLE_RST)
for i in data:
st_return_i = np.prod(data['daily_return_'+i]+ 1 ) - 1
bench_return = np.prod(bench['daily_return_'+i]+ 1) - 1
# Calculation of Standard Deviation and Downside Deviation
std_i = data['daily_return_' + i].std()*np.sqrt(252)
data['DD_' + i] = data[data['daily_return_' + i]<0]['daily_return_' + i]
dd_i = data['DD_' + i].std()*np.sqrt(252)
# Calculation of Beta
beta_i = stats.lineregress(data['daily_return_' + i].dropna(),bench['daily_return'].dropna())[0]
# Calculation of Tracking Error
te_i = (data['daily_return_' + i] - bench['daily_return']).std()*np.sqrt(252)
# Calculation of Sharpe Ratio
sharpe_i = (st_return_i - RF/100) / std_i
# Calculation of Sortino Ratio
sortino_i = (st_return_i - MAR/100) / dd_i
# Calculation of Treynor Ratio
treynor_i = (st_return_i - RF/100) / beta_i
# Calculation of Information Ratio
information_i = (st_return_i - bench_return)/ te_i
column = (i,str(round(st_return_i*100,2))+'%',str(round(bench_return*100,2))+'%',str(round(std_i*100,2))+'%',
str(round(dd_i*100,2))+'%',round(beta_i,2),str(round(te_i*100,2))+'%',round(sharpe_i,2),round(sortino_i,2),
round(treynor_i,2),round(information_i,2))
table.rows.append(column)
print(table)
Thank you very much.
