Buffer kept increasing under windows 2016
WeChat Image_20210329202638.jpgDear team
Our client has switched OS to jdk8 windows server 2016 but found their api developed with rfa lib are not working the same that was on windows 2008. Please find attached screenshot. It seems the buffer is unable to be reset. Could you please advise how to fix or if any way to avoid it? Thank you.
client api was developed with rfa 7.2.0.
elektronrefinitiv-realtimeelektron-sdkrfa
Hi @Xiaorong.Xu
The key thing to note here is that RFA 7.2 is an unsupported version - it was End of life in 2014.
They should upgrade to the latest v8.x or at least 7.7x as a minimum
Thank you @umer.nalla,Please could you confirm if this is the link for client to download the latest SDK?
https://developers.refinitiv.com/en/api-catalog/thomson-reuters-enterprise-platform/robust-foundation-api-rfa-java
23k 22 9 14
Hello @Xiaorong.Xu,
If you would like to download RFA 7.7, please use link Refinitiv Robust Foundation API (RFA) - Java as suggested by @umer.nalla
Please note, as RFA API is feature complete and not among the recommended for the new development, the access to SDK will need to be requested and approved.
