Can using the Eikon python API make the desktop APP and other services slow?
Good morning,
In our company we have some scripts running on the machine that we have the Eikon desktop, all related to Eikon services. One of these scripts is made in python and uses the API with the Streaming Prices method, however we noticed that sometimes the desktop APP is slower and the other services respond to many timeouts.
My question is: can the use of this streaming script be affecting the performance of other services?
And something related would be: could it be something related to the limitation of requests?
I know that none of the other scripts exhaust the number of daily requests (10,000 if I'm not mistaken, right ?!), but with this script making 200 rics with high frequency ticks, is it possible that this is the reason? It was not clear to me in the documentation how requests are counted when using Streaming Prices, could you elaborate?
Thanks in advance,
Diego Soares.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonstreaming-prices
18k 21 12 20
Hi @diego37
The request in the Streaming Prices does not count towards limitation.
I believe that the reason is that you are consuming 200 "high frequency" instruments.
So the processing/callback might not be able to catch up with the incoming updates.
If you need a real-time data feed, you may consider an enterprise product such as Real-Time Optimized feed.
Please contact your Customer Success Manager to get more information about the product which may serve you better.
But is it possible that this script is slowing down others services?
Hi @diego37
It could be possible.
I can give you a few scenarios.
- Assuming that the "high update rate" 200 rics already exhausted almost all of your machine network bandwidth. So other requests will have to be queued out and it could fail, timeout, etc...
- Assuming that your script spends most of your CPU time to handle the "high update rate" 200 rics, so it could slow down other applications, processing power on the same machine.
I could not say for sure that this is an issue you are experiencing.
I think the best way is to get CSM to discuss with you on the requirement.
So they can bring in the best solution for you.
OK, thank you for the attention!
