Hi, I saw this https://www.finextra.com/pressarticle/60079/tick42-releases-openmama-bridge-for-thomson-reuters-trep-platform but it specifically references TREP, but will it be still compatible with EMA? (hoping that it was a rebranding only).
Hi @simon.dando
I think the "TREP Bridge" is a product from tick42.
It uses "Ultra Performance API" (UPA) to connect to "Thomson Reuters Enterprise Platform" (TREP)
Please note that UPA has been rebranded to "Elektron Transport API" (ETA) and then to "Enterprised Transport API" (ETA).
Please note that TREP has been rebranded to "Refinitiv Real-Time Distribution System".
If your question("compatible") means "Can you use EMA to connect to TREP Bridge" or "can TREP Bridge use EMA to connect to TREP"?
- I think you have to contact tick42 to clarify this.
Thanks Chavalit. I'll definitely contact tick42 also, but can you check if there are any TREP features that have either been removed or aren't backward-compatible since they were move to ETA? Was it only a rebranding?
Hi @simon.dando
The connection UPA and ETA supported is called "RSSL connection" and the data being transported is "RWF".
It is still the same Refintiv proprietary protocol.
So you won't miss anything.
