RE: Case : 09719381 Eikon API not working. used this link to solve the issue. https://developers.ref - from Refinitiv [ ref:_00D30602X._5001W1m0HvB:ref ]
Case:09719381
Dear Denis Vernet,
Thank you for contacting the Help Desk.
I have received your query with the following details:
Case Description :
Eikon API not working. used this link to solve the issue. https://developers.refinitiv.com/en/article-catalog/article/eikon-data-api-python-troubleshooting-refinitiv
the part that is not working is from section
3.4. Browse into sub-folder TRD then to the most recent created folder with "Eikon.<datetime>.p<process-ID>" folder.
Then open the "SxS.<datetime>.p<process-id>.txt" file
I do not have that file. how can I make sure that I have it ?
concerning the rest of the steps and the localhost check, it seemed to me that they were already well set.
Here a couple of screenshots to make clear what is the source of the error "Port number non-identified" and the screenshot showing that within my TRD scripts the SxS file is not the same of the API Eikon resolution guide provided by the forum.
18k 21 12 20
Hi @denis.vernet
I checked that your account has access to the Eikon Desktop product.
My general suggestion would be to uninstall the product, restart your machine, re-install the product and restart the machine again.
Then launch the product and try the API from the same physical machine that you have Eikon Desktop running.
I also contacted the 09719381 case owner to get it escalated to an appropriate support group.
Hello @chavalit.jintamalit,
many thanks for your intervention. I have been contacted by another colleague of yours too and now I will implement both of your suggestions. Fingers crossed, thanks ! and take care
