ek.get_data for USD1YOIS=
I am trying to retrieve information for Overnight Index Swaps. I have RICs like USD1YOIS= or COP1YOIS= and I am using the following code to get the data:
ts2,e2 = ek.get_data('USD1YOIS=',
["TR.MIDYIELD.date","TR.MIDYIELD"],{'SDate':start_date,'EDate':end_date,'Frq':'D'})
I have tried using the fields TR.MIDYIELD or TR.MIDPRICE but I don't get any information.
I have looked in the Data Item Brower for fields that have time series data but couldn't find any.
Do you know what field should I use? Thanks!
PD: I am able to get the data from an excel spreadsheet using =@RHistory and the field Close. However using the python code I can't get it.
6.7k 8 6 7
@andrgome Hi I would use the refinitiv data platform (RDP) library for this - which you can use with your app key:
import refinitiv.dataplatform as rdp
rdp.open_desktop_session('YOUR APP KEY HERE')
rdp.get_historical_price_summaries(
    universe = 'USD1YOIS=',
    interval = rdp.Intervals.DAILY,
    count = 500)
Please also note that the refinitiv.dataplatform library also contains a full version of the eikon library which you can use by:
import refinitv.dataplatform.eikon as ek
ek.set_app_key('Your App Key Here')
So you can use both APIs from one package.
I hope this can help.
Hi @jason.ramchandani. Thanks for your help. This works! Quick question. I managed to get USD1YOIS using the following code.
OIS = rdp.get_historical_price_summaries(universe = 'USD1YOIS=',
start = "2005-12-31",
end = "2021-03-17",
fields = ['MID_PRICE'])
I tried to get more RICs like USD2YOIS or something else but I did get an error with the following code.
OIS = rdp.get_historical_price_summaries(universe = ['USD1YOIS=''USD2YOIS='],
end = "2021-03-17",
Do you know what is the right syntax to make it work?
Thanks!
@andrgome
I think that it supports one item for each call.
    universe = 'USD2YOIS=',
    count = 500)
Hi @andrgome,
You can try to use the timeseries function in Eikon data API. The data provided is intervalized bar data.
>>> ek.get_timeseries('USD1YOIS=', start_date='2019-10-10T15:00:00', end_date='2021-01-10T15:00:00', interval='monthly')
USD1YOIS=   CLOSE   HIGH    LOW   OPEN
Date
2019-10-31  1.371  1.535  1.296  1.502
2019-11-30  1.422  1.496  1.388  1.367
2019-12-31  1.498  1.513  1.415  1.425
2020-01-31  1.332   1.51  1.346  1.489
2020-02-29  0.901   1.45  0.849  1.334
2020-03-31  0.044  0.888  0.065  0.888
2020-04-30  0.034  0.082   0.05  0.064
2020-05-31  0.015  0.038  0.001  0.031
2020-06-30  0.018  0.054  0.031  0.002
2020-07-31  0.018   0.03  0.027  0.015
2020-08-31  0.037  0.056  0.035  0.007
2020-09-30  0.046  0.051  0.054  0.039
2020-10-31  0.051  0.062  0.063  0.031
2020-11-30  0.048  0.073  0.067  0.037
2020-12-31  0.066  0.073  0.081  0.063
The TR.MIDYIELD field that you are trying to use is not applicable to Fixed Income Asset class.
For any more help regarding data, please raise a service ticket at my.refinitiv.com to speak to a content expert. We can only answer technical question on these forums.
Thank you! This works! However this get_timeseries has some data limits, hence to get a long history is impossible.
