Snapping zero-values with the Python RDP library
I'm using the latest release of the RDP python library (1.0.0a7.post7), in particular the get_snapshot() function of the StreamingPrices class. If the value I'm snapping happens to be a float equal to zero (say a yield of 0%), the function get_snapshot() returns None. This is confusing since None is also returned if no value could be found.
Is it possible to make RDP return the value 0 instead of None when the field contains the value 0?
The issue seems to be caused by line 266 in StreamingPrices.py which treats non-existing fields the same way as fields with a value of 0: if _all_fields_value[name].get(f) else None
rdp-apirefinitiv-data-platform
Hi @Sabina Tanase
Apologies - a misunderstanding.
I have been advised by the RD Library team that this bug has been fixed in refinitiv-dataplatform 1.0.0a8.post2 - which will be available soon on PyPi.
I will try and update once I know it is available.
Hi @Sabina Tanase
Thanks for reporting this issue - I have passed it on to the RDP Python library dev team and will get back to you once I get a response / fix release details.
chased the RDP team for an update again.
Hi @Sabina Tanase
RDP team have advised that a fix for this should be in the end of Q1 release - no exact date yet.
