why do HistoricalPricing.get_summaries() with interval other than minutely or daily, not work?
It appears that when extracting data via refinitiv.dataplatform.HistoricalPricing.get_summaries(), only the minutely interval and the daily interval work. See the example below.
import refinitiv.dataplatform as rdp
grant = rdp.GrantPassword(username=RDP_LOGIN, password=RDP_PASSWORD)
rdp.open_platform_session(APP_KEY, grant)
rdp.logging.disable()
for interval in rdp.Intervals:
    response = rdp.HistoricalPricing.get_summaries('GBP=', interval=interval, count=5)
    print('\ninterval name=%s value=%s\n%s'
          % (interval.name, interval.value, response.data.df[['BID', 'ASK']].head()))
interval name=ONE_MINUTE value=PT1M
BID ASK
2021-03-12 21:56:00 1.3916 1.3921
2021-03-12 21:57:00 1.3919 1.3924
2021-03-12 21:58:00 1.3918 1.3923
2021-03-12 21:59:00 1.3922 1.3927
2021-03-12 22:00:00 1.3922 1.3927
interval name=FIVE_MINUTES value=PT5M
BID ASK
interval name=TEN_MINUTES value=PT10M
BID ASK
interval name=THIRTY_MINUTES value=PT30M
BID ASK
interval name=SIXTY_MINUTES value=PT60M
BID ASK
interval name=ONE_HOUR value=PT1H
BID ASK
interval name=DAILY value=P1D
BID ASK
2021-03-08 1.3824 1.3828
2021-03-09 1.3893 1.3896
2021-03-10 1.393 1.3934
2021-03-11 1.399 1.3994
2021-03-12 1.3922 1.3927
interval name=SEVEN_DAYS value=P7D
BID ASK
interval name=WEEKLY value=P1W
BID ASK
interval name=MONTHLY value=P1M
BID ASK
interval name=QUARTERLY value=P3M
BID ASK
interval name=TWELVE_MONTHS value=P12M
BID ASK
interval name=YEARLY value=P1Y
BID ASK
rdp-apirefinitiv-data-platform
@gabriel.borrageiro.20
It looks like to be a bug as mentioned in this thread.
The workaround could be like the following.
endpoint = rdp.Endpoint(
    session = rdp.get_default_session(), # Optional
    url = "/data/historical-pricing/v1/views/intraday-summaries/JPY=")
response = endpoint.send_request(
    method = rdp.Endpoint.RequestMethod.GET,
    query_parameters={
        'interval': 'PT1H',
        'count': 5,
        'summaryTimestampLabel': 'endPeriod'
if response.is_success:
    headers = [h['name'] for h in response.data.raw[0]['headers']]
    df = pd.DataFrame(data=response.data.raw[0]['data'], columns=headers)
    display(df)
thanks, that appears to work.
any idea as to how one can specify an ending date / time?
this did work with rdp.HistoricalPricing.get_summaries():
end=datetime.utcnow()
it doesn't appear to work with the code you supplied.
I get an error message:
response.status
Out[12]:
{'http_status_code': 400,
'http_reason': 'Bad Request',
'error': {'id': 'bf914859-de80-476e-810c-5ab748c6b9a8',
'code': 'TS.Intraday.UserRequestError.90004',
'status': '400',
'message': 'Request Validation Error',
'errors': [{'key': 'end',
'reason': 'The request parameter validation failed. end is invalid format.',
'invalidValues': ['2021-04-14T11:43:57.132911']}]}}
