The return value of /cases/{ {case-system-id}}/auditEvents are the ones in enum. Is there another API to retrieve the text as printed in PDF export?
Case Id: 5nzbfqb2g2am1fg8en749n0hx
Case output from Web UI PDF export
Any document to generate the same text in PDF?
You can probably explore how you can map these details and write a login in your code to probably save them in a text file if that is possible.
