How to connect to Eikon via python from MS power-bi?
I am trying to connect to Eikon via python from MS power-bi.
Power bi has a connector for python. If I use following script (which works in jupyter):
import eikon as ek
import pandas as dp
ek.set_app_key('########################################')
df, err = ek.get_data(['PEUP.PA','EUR=','JPY='], ['BID','ASK'])
df
power-bi gives following error message:
Details: "ADO.NET: Python script error.
Traceback (most recent call last):
File "PythonScriptWrapper.PY", line 10, in <module>
import eikon as dp
File "C:\Users\ \Anaconda3\envs\refinitiv\lib\site-packages\eikon\__init__.py", line 12, in <module>
from .Profile import *
File "C:\Users\ \Anaconda3\envs\refinitiv\lib\site-packages\eikon\Profile.py", line 17, in <module>
from .streaming_session import DesktopSession
File "C:\Users\ \Anaconda3\envs\refinitiv\lib\site-packages\eikon\streaming_session\__init__.py", line 3, in <module>
from .session import *
File "C:\Users\ \Anaconda3\envs\refinitiv\lib\site-packages\eikon\streaming_session\session.py", line 8, in <module>
import httpx
File "C:\Users\ \Anaconda3\envs\refinitiv\lib\site-packages\httpx\__init__.py", line 2, in <module>
from ._api import delete, get, head, options, patch, post, put, request, stream
File "C:\Users\ \Anaconda3\envs\refinitiv\lib\site-packages\httpx\_api.py", line 3, in <module>
from ._client import Client, StreamContextManager
File "C:\Users\ \Anaconda3\envs\refinitiv\lib\site-packages\httpx\_client.py", line 5, in <module>
import httpcore
File "C:\Users\ \Anaconda3\envs\refinitiv\lib\site-packages\httpcore\__init__.py", line 2, in <module>
from ._async.connection_pool import AsyncConnectionPool
File "C:\Users\ \Anaconda3\envs\refinitiv\lib\site-packages\httpcore\_async\connection_pool.py", line 2, in <module>
from ssl import SSLContext
File "C:\Users\ \Anaconda3\envs\refinitiv\lib\ssl.py", line 98, in <module>
import _ssl # if we can't import it, let the error propagate
ImportError: DLL load failed while importing _ssl: Das angegebene Modul wurde nicht gefunden.
Why is it not working?
Many thanks in advance
Ludwig
@calice.l
This error is not related to any Refinitiv software. To verify, you can replace your code with a single line
import _ssl
My expectation is that with the above line of code you will reproduce the same error. Or more precisely the last part of it: "ImportError: DLL load failed while importing _ssl: Das angegebene Modul wurde nicht gefunden".
The error is related to the setup of your Python environment. There may be numerous reasons for the root cause. Here's a link to a thread on Stackoverflow, which may be useful.
https://stackoverflow.com/questions/54175042/python-3-7-anaconda-environment-import-ssl-dll-load-fail-error
The reason why it works in Jupyter and not in Power BI must be that your Jupyter and Power BI utilize different Python environments.
Hi Alex,
thanks a million! Copying
-   libcrypto-1_1-x64.dll
-   libssl-1_1-x64.dll
into respective envs DLLs worked!
Ludwig
