I try to get .SETITRI data. But data is not available on 5 Mar 2018, while '.SETI' is available.
I retrieve this data using Python API. Since it's working date of stock exchange of Thailand, could you please help check?
Thank you.
Thank you.
Hi @warin.c
I just tested the API and also compare the data from the Eikon Chart application.
It seems that the data point is not available on 5th March 2018.
I also tested .SETI and can see that the data point on 5th March 2018 is available.
If you want to clarify the content, whether there is missing content?
This forum is not the best place to ask about content questions.
For an authoritative answer to any content questions, the best resource is the Refinitiv Content Helpdesk.
This forum is dedicated to things specific to the use of Eikon APIs.
The moderators here do not have deep expertise in every type of content available through Eikon.
The Refinitiv Content Helpdesk can be reached using Contact Us capability in your Eikon application.
