What is the meaning of Name in Refresh message on successful login
I was not able to find relevant information in Protocol Specification.
Could you please explain what is the meaning of Key::Name field in RefreshMessage with Domain Login:
I used API Playground for streaming/pricing/v1 to get the following response:
"ID": 1,
"Type": "Refresh",
"Domain": "Login",
"Key": {
"Name": "AQIC5wM2LY4SfcxLk5nRbPAY8SEQYLD72qqSwzEhZ2ziIEU%3D%40AAJTSQACMTAAAlNLABE1Njc4NjMzODQ5MTg2MzI0NwACUzEAAjI2%23",
"Elements": {....
The string "AQIC5wM2LY4SfcxLk...." - what does it contain? how can we use it?
treprdp-apiwebsocketsrrtolog-inrefresh
11.5k 16 7 10
Hello @Aigerim.Mukusheva
The value of Refresh Response's Name parameter is generated from the back end side (Refinitiv Real-Time infra, etc).
The WebSocket consumer application does not use it because the application uses the "ID" attribute as a reference.
