If yes, i have four api, which one out of four should i use for my python RDP api? Any help would be greatly appriciated.
Hi @filip.shu
You have shown the 4 AppKey names - if you refer to the API Type column on the far right of the AppKey Generator - you will see the API Type e.g. for my AppKeys I have the following types:
You can use Eikon Data API AppKey with Eikon Data API and EDP API for RDP API,
