Backend error. 500 Internal Server Error
hello,
I have the following issue all codes worked find before:
Still Working:
import eikon as ek
ek.set_app_key('xxxx')
ek_start = '2011-01-01'
ek_end = '2021-01-01'
symb = '1067651MSHT'
ek.get_timeseries(symb, start_date = ek_start , end_date = ek_end)
Not working:
import eikon as ek
symb = '1067651MSPD'
Backend error. 500 Internal Server Error 2021-02-24 21:53:07,025 P[22304]
HTTP request failed: EikonError-Backend error. 500 Internal Server Error
I already checked similar issue on the forum but none of them worked,
Seems to crash randomly on a RIC,
Do you have internal issue ?
Best
Antoine
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonerror-500
There are numerous reasons why an HTTP request may occasionally fail. If this happens randomly and infrequently, a simple workaround is to catch the error and re-request the data. If this happens frequently or if you're able to consistently reproduce the problem, I suggest opening a support case with Refinitiv Helpdesk. Refinitiv Support can be reached by calling the Helpdesk number in your country, using Contact Us capability in Eikon application or by visiting MyRefinitiv.
