What is difference between World-Check One API v1 and World-Check One API V2?
You can switch from v1 to v2. Only the url changes from v1 to v2 ( in each section of the Authorisation format ). Since v2 is the current version we would recommend you to try out the v2 version in the pilot environment
Version v2 has all the capabilities of v1 plus below capabilities -
- Bulk Screening ( Asynchronous ) - ( up to 50 cases be created using 1 API call )
- Bulk retrieve screening status - ( Screening status of up to 50 cases can be retrieved using 1 API call )
- Sync screening - (Returns the caseSystemId in response along with results)
- Link / Unlink cases ( link/unlink cases to each other )
- User Activity monitoring
- Retrieve MRZ lines (Passport check)
- Media-Check screening
- Media Check results
- Media Check articles - ( Attach / Remove )
You may download the collection and the environment from the following link - "https://developers.refinitiv.com/en/api-catalog/customer-and-third-party-screening/world-check-one-api/documentation" .
Hope this helps.
If we do not want any new functionalities of v2 version and still if we switch to v2 version on production then will it have any impact?
Can you please provide us the workflow of your API calls or the endpoint which you are using at the moment?
Please let us know if below endpoints will have any impact due to version change from v1 to v2.
Thanks for your query.
V1 is the older version of the API and v2 is the latest version of the API. The v2 version has more capabilities including Media-Check screening via the API.
Can you please let us know what specific information is needed regarding v2?
We are currently on V1 version on production as well as on pilot environment.
We are planning to change WC API url from in-premises URL to AWS URL for production environment.
Wanted to know if we need to move to v2 version or we should stay on v1 version?
If we have to change from v1 to v2 then what are the thing we should take care?
What are the advantages of V2?
