How to know if Gender and Category (PEP / LE / RE / OB / Sanction) is updated for a WC1 profile
We are using Refinitiv Worlcheck API for AML screening. In our application, we need to show updated AML matches and also show fields that have been updated.
To show the fields that have been updated we use the updateDates object to get the fields that have been updated for the profile. For most of the fields it is ok, but there is no indicater for Type and Gender. Is there a way to get this. Thanks
world-checkworld-check-one
@devops.kyc,
Please refer to the below document available in the help section of the UI.
Link - https://my.refinitiv.com/content/dam/myrefinitiv/products/10834/en/UserGuides/610868.pdf
@prabhjyot.mandla
I could not find either Gender or Type on the update categorization. Does that mean, we will have to do manual checks to determine if these fields were updated.
@devops.kyc,
Yes, you will have to manually check it. I will get back to you if I find anything useful on this matter.
