RFA API download page "Approval pending"
Hi Refinitiv and all,
I'd like to download RFA API kit for my integration work, asked to be a "member" week ago, but I still see "Approval pending" message on download page. How long the process typically take and is there anything more I could do to get access to downloads?
Thank you,
David
treprfarfa-apiDownload
Hi @david.simonek
Thanks for confirming that you are now able to login and download.
For the Java language, the Enterprise Message API (EMA), which is part of the Refinitiv Real-Time Java SDK is recommended as the strategic API choice for 95% of development needs.
If you require the lowest possible latency / highest throughput etc then the Enterprise Transport API (ETA) from the same SDK could be worth exploring.
However, for the majority of Java developers, EMA is recommended.
Refinitiv Real-Time Java SDK | Refinitiv Developers
Key benefits of using Refinitv Real-Time SDK over RFA:
Cloud-native support - develop an application against your deployed Refinitiv Real-Time Distribution System (formerly known as TREP) and you can easily change the app to consume data from our Cloud-based real-time distribution system if required in the future.
Future-proofing - longer-term OS and Compiler support
Refinitv Real-Time SDK is Open Source
EMA is easier to learn and easier to maintain long term
  • EMA is easier to use, Less code to write and maintain
  • Improved resources - training, tutorials, examples, articles, use cases
Feel free to compare the source code for examples supplied with each API e.g. a basic RFA consumer example such as QuickStartConsumer with an EMA example such as series100\ex120_MP_FieldListWalk OR compare the RFA Consumer Tutorials with the EMA Java Consumer Tutorials
EMA Java Tutorials
RFA Java Tutorials
