API Key - Trusted Destination
We wanted to check if there are other ways in order not to use the API key and make the destination as a trusted destination from SAP?
world-checkworld-check-one
The requirement is to have an RFC destination which does not ask for API key/secret. Is this possible?
1.1k 3 1 2
@alfredo.aquino
Yes, You're right as you saw in the postman pre-request the way authorization has been done.
I am sure it is possible from SAP as we have had clients connect using SAP connect to World-Check before.
I am no expert at SAP but I would be happy to get on a call with you and speak more about how to build the authorization and have a discussion on how you can connect with SAP.
Let me know your availability for Monday or early next week whichever is feasible for you, I will send out an invite.
Hello Mehran,
Can you please schedule a call/meeting at 5PM, Manila Time, on February 16? Thank you!
@alfredo.aquino
Sure, sending out an invite
1.1k 3 1 2
@alfredo.aquino
Message authentication is managed via API keys and HMAC-based message signatures. Every API request needs a message signature in order for it to be processed and you will have to use the API key and Secret to formulate the established authorization process.
You can read more on the Authentication on our developers' community using the link below:
https://developers.refinitiv.com/en/api-catalog/customer-and-third-party-screening/world-check-one-api
Does that mean that there is no way not use API Key/Secret? In every transaction, we will be needing this one? I was wondering if we can explore a trusted connection to SAP. Is this possible?
@alfredo.aquino
unfortunately, at this moment we don't have that option available.
You will have to use the API key and secret and formulate the authorization everytime you want to connect to World-Check One API.
Hello Mehran,
We are trying to connect to World Check via RFC in SAP side. Unfortunately, the API key and secret does not work.
From CPI perspective, there were some authorizations made as well from Postman in order to authenticate. How do we do that kind of authorization from SAP side in order to connect to World Check? Is it possible?
