Getting Parse Error while trying to establish a SXS session using the handshake request
Hi, I am trying to set up the environment to use the Side By Side Interoperability API.
For this I was referring to the Quick start guide that is available at this link : https://developers.refinitiv.com/en/api-catalog/eikon/side-by-side-integration/quick-start
I successfully started and logged in to Eikon. Then, I was also able to successfully ping the SXS server using the Postman Utility at port 9001 (since 9000 was being already used on my system).
After this, I was trying to establish a Session and for this I first generated the Product ID and App key using the App key generator in Eikon
and then passed the below JSON object
"command": "handshake",
"productId": "SWITCHANDDATASYSTEMS.EIKOND.......",
"appKey": "1d8281c18........"
I followed all the steps that is mentioned in the Quick start guide to establish a SXS session. I ensured that the raw data is selected and the type of data is set to JSON within the Postman utility.
However, on posting the above JSON, I am getting the below error in response
"isSuccess": false,
"error":
"code": -32700,
"message": " Parse error"
It seems there is some Parsing error but the JSON object that I am passing seems to be correct.
Please refer the below image
Could you please help with this.
side-by-side-api
@Vaibhav.Gandhe
If you copied the request from the website, it may contain invalid characters.
Please manually type the request.
