can't connect to eikon via python
Hi, I am trying to connect to Eikon from python. My code has always worked but suddenly won't, even after I have restarted my machine.
import eikon as ek #Import library for python API wrapper
ek.set_app_key( XXXXXXXX )
I keep getting this message;
2021-02-03 19:17:18,985 P[14748] [MainThread 14724] Error on handshake port 9060 : TimeoutException('TimeoutException on HTTP request: ReadTimeout()')
Can you please advise? Thanks
@ajalden
The problem looks similar to this thread.
You may need to check the followings:
  1. Check python dependency versions by running pip list command and verify the version of Eikon Data API, httpx, and nest-asyncio
  2. Activate debug log in your script to retrieve more detail by using the below code
 ek.set_log_level(1)
 ek.set_app_key(APP_KEY)
I should add that my Eikon desktop app is currently open and working
