Accessing Local Service with RDP service name
Hi
I am looking to steam prices from a local RMDS source 'DTS_SG'
I attach a screen shot of the configuration in Eikon
I am trying to access the local service via RDP and streamingprices, with no luck
What should be the value I pass to the service parameter. I have tried ('D'.'DTS_SG','DTS_SG_RDF','D_RDF') to no avail
session = rdp.open_desktop_session(app_key='**)
session.set_log_level(logging.ERROR)
def create_dataframe(data):
df = pd.DataFrame(data=streaming_prices)
print(df)
streaming_prices = rdp.StreamingPrices(
universe = ['PYTHONRECORD'],
service = 'DTS_SG',
fields = ['BID', 'ASK'],
on_complete = lambda streaming_prices :
create_dataframe(streaming_prices),
on_update = lambda streaming_price, instrument_name, fields :
print("Update received for {}: {}".format(instrument_name, fields))
streaming_prices.open()
Record
Configuration
rdp-apirefinitiv-data-platform
Hi @Joseph.Maloney
Currently, the Eikon Data API (API Proxy) gets streaming data from the platform directly (HMDS) so you should not have access to local services like DTS etc
In the meantime, if you are able to do so, please try using a PlatformSession instead e.g.
rdp.open_platform_session(     APP_KEY,      deployed_platform_host = 'myADS1:15000',     deployed_platform_username = 'umer.nalla' )
You will need to speak to your MarketData team to get the hostname or IP address of an ADS server and also your DACS user name. You should also confirm the Websocket Port is 15000
You should then be able to specify the servicename as described o the other post Getting Data from a different RMDS source (not the live feed) - Forum | Refinitiv Developer Community
e.g.
service = 'DTS_SG',
universe = universe,
fields   = fields, .....
I was now able to test the above and it is working as expected..
