Error on handshake port 9060 : TimeoutException
I have the following error when trying to access Eikon API using Python.
 Error on handshake port 9060 : TimeoutException("TimeoutException on HTTP request: ReadTimeout('')")
My Python packages and applications related to Eikon are as follows.
Python packages:
- python 3.9.1
- eikon 1.1.8
Applications:
- Eikon Desktop 4.0.52055
- Eikon API Proxy 9.52.0.51
Also, setting environment variables are as follows because of using proxy server for the internet connection.
- HTTP_PROXY = http://username:password@proxyhost:port
- HTTPS_PROXY = http://username:password@proxyhost:port
- NO_PROXY = localhost,127.0.0.1
Can you help me?
@daichi.yuasa.b
Thank you for the information. All data retrieval from Eikon platform using Eikon Data APIs is via HTTPS port 443, hence I don't think the fact that you cannot telnet to apac1.apps.cp.thomsonreuters.com on port 80 is a concern for the issue you experienced.
For further investigation, could you please increase the logging level in Eikon Data APIs library for Python as follows before calling set_app_key method, and include the full output?
ek.set_log_level(1)
ek.set_app_key(YOUR_APP_KEY)
And could you also try retrieving some data, e.g.
ek.get_data('IBM.N', 'TR.Revenue')
@Alex Putkov.
I have attached the log file I got by running as below, Could you check it, please?
import eikon as ek
ek.set_log_level(1)
ek.set_app_key('xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx')
pyeikon.20210127.02-38-26_mod_key.log.txt
Thank you for the log. We need to continue investigating this issue with Refinitiv Support. I raised case 09567134 on your behalf with Refinitiv Helpdesk. You will be contacted by the Helpdesk.
6.7k 8 6 7
Hi @daichi.yuasa.b Please could you tell me what library versions of the following you are running httpx, nest-asyncio? This thread maybe able to assist you as it deals with a number of possible solutions. For a start I would start with Python 3.8x. But let me know how you get on. I hope this can help.
Thanks @jason.ramchandani
Please confirm my using library versions as indicated below.
  • httpx : 0.14.3
  • nest-asyncio : 1.3.3
6.7k 8 6 7
@daichi.yuasa.b Your httpx and nest-asyncio libs are correct. Also please can you confirm with your IT team that you have opened firewall access for the following (not sure which region you are in so I put all regions):
emea1.apps.cp.thomsonreuters.com 159.220.1.19
amers1.apps.cp.thomsonreuters.com 159.220.40.41
apac1.apps.cp.thomsonreuters.com 159.220.16.215
I have seen many issues where firewalls have been updated - so please do check that and confirm please.
@jason.ramchandani Thanks for your advice.
Do I have opened firewall access for apac1.apps.cp.thomsonreuters.com to use Eikon API from Japan?
@daichi.yuasa.b Yes thats correct - see if that fixes things.
May I ask one more question?
Does Eikon API need to access on port 80/443 for apac1.apps.cp.thomsonreuters.com?
6.7k 8 6 7
@daichi.yuasa.b I need to check this and get back to you - apols for delay.
