I'm using the REST API on TREP 3.4.
I want to list all the RICs subscribed by one specific user. Is it possible?
Hi @nicolas.roux, The REST API interface cannot be used for retrieving user stats from ADS. You will have to use a monitoring tool like ADSMON to see the list of subscribed RIC's.
Hello @nicolas.roux,
I see on My Refinitiv the latest documentation resource for ADS REST access, if you visit MyRefinitiv -> ADS it contains
"Refinitiv Real-Time Distribution System 3.5 Online Documentation Library" which is an online resource that is designed to be searchable.
REST access documentation is part of ADS Installation Manual.
I note that you are on 3.4, however, please observe that 3.5 REST interface does not include per user Item Database requests, so the same would apply to 3.4 ADS.
Hope this helps.
This forum is intended to help developers with the usage of Refinitiv APIs included under API Catalog of Developers Portal.
For more in-depth help on TREP infra administration, as a customer, you may need to involve Refinitiv Helpdesk Online.
