the formula must contain contain at least one field or function Eikon API
Hi, we have some fields to retreive data with python, this fields are for balanceSheet, IncomeSheet and CashFlow Data.
p = {
'Period': 'FY0'
, 'reportingState':'Orig'
, 'curn': currency
, 'Scale':'6'
, 'SORTA':'LISeq'
, 'CH':'Fd'
, 'IncludeOldYE' :'No'
, 'ReportType':'Latest'
, 'Edate' : '-10FY'
, 'FRQ':'FY'
, 'transpose':'y'
, 'Sdate' : '0FY'
, 'FXRate' : 'PeriodEnd'
, 'NULL' : 'blank'
df, err = ek.get_data(['BAP.LM'], ['TR.F.BalanceSheet.fieldName','TR.F.BalanceSheet.fielddescription', 'TR.F.BalanceSheet.date','TR.F.BalanceSheet'], parameters = p )
We handle the translate for the all fields, so we obtain the name of the field in english to build this json Example:
"key": "TR.F.AssetParticipFactorIssue ",t
"lang": {
"es": "Factor de participación de activos: tema específico ",
"en": "Asset Participation Factor - Issue Specific"
but for the followings fields ge got The formula must contain at least one field or function vía excel.
TR.F.PPEExclROUTangCapLeaseNet
TR.F.PPEExclROUTangCapLeaseGross
TR.F.PPEExclROUTangCapLeaseAccumDepr
TR.F.TotOpLeaseLiab
TR.F.FinOpLeaseLiabTot
TR.F.DebtInclFinOpLeaseLiab
TR.F.InterestEarnLiabAvg
I wondering if there is a way to obtain at least the name of the fields even if the field does not have data.
I forgot add this image
18k 21 12 20
Hi @isanchez
I think these fields are invalid fields.
TR.F.TotOpLeaseLiab
I try adding TR.ZXCVB as an invalid field.
Then I add at least a valid field and all the invalid fields are omitted in the result.
Hello @chavalit.jintamalit
When you said that maybe the field are invalid, this is invalid for the current ric or is invalid for any ric
@isanchez
You can directly contact the Eikon support team via MyRefinitiv to verify the usage and scope of those fields.
