Reuters Eikon COM: Time Series Chart - How to base different stock prices to different dates? when firms started operations at different times
I am using Reuters Eikon and I want to plot Time Series Charts. I want to plot the stock prices of different firms starting in 2017 with the base 0. My problem is that only two firms are starting there. Two other firms are starting in 2018 and 2019 but they also use 2017 as a base in order to compare the development of all stock prices, which means they are starting not form zero but another value. How can I set the dates I want to refer to as a base individually? So that the firms which are starting later also start at 0.
eikoneikon-com-apitime-seriesthomson-reuters
Since you posted this question on a forum dedicated to software developers using Refinitiv APIs I assume you're looking for a programmatic solution. Here's an example using Eikon Data APIs.
# get timeseries of price history for IBM & Airbnb
df = ek.get_timeseries(['IBM.N','ABNB.O'],['CLOSE'],
                      start_date='2020-11-05',end_date='2021-01-08')
# backfill missing price history for Airbnb
df['ABNB.O'].fillna(method='bfill', inplace=True)
# rebase price history
df = df/df.iloc[0] - 1
# display rebasing plot
ax = df.plot() ax.axhline()
However, if you're asking how to use a chart object (CHT) in Eikon application, when inserting an Indexed Price Performance / Rebasing Analysis in a chart app, one of the Analysis parameters is "Specified Date", which is set separately for each instrument.
Or you may want to consider using Financial Chart app, which does not require specifying rebasing date for each instrument and just starts the plot at zero on the first date available as long as "Normalize dates" option is set to Off.
If you need further help with Eikon apps, please contact Refinitiv Helpdesk using Contact Us capability in your Eikon application. This forum is dedicated to software developers utilizing Refinitiv APIs.
