DSWS Python wheel is up on pypi.org so is pip installable but is there any corresponding conda package so that its easily installable by others using conda?
I believe that the development team aware of the requirement but it still has no plan to release the conda package very soon as mentioned in the following posts. https://community.developers.refinitiv.com/questions/44887/conda-install-eikon-101-windows.html
Hi @Midori.Miyata1,
You may use the conda package "datastreamdsws" in 'Environments':
Please make sure to select 'All' in the top-left dropdown to see all available packages. In my example capture above, it says 'Installed' for example.
Does that answer your questions?
Thank you for your reply.
I have tried but DSWS does not shows in the link.
https://anaconda.org/search?q=datastreamdsws
https://anaconda.org/search?q=dsws
For example, it shows as below if it is supported (the top one is the official one)
https://anaconda.org/search?q=blpapi
Would you please advise?
Hi @Midori.Miyata1,
I'm afraid that 'datastreamdsws' - just like 'eikon' - Python libraries are not packaged in Conda, and thus cannot be installed via the Anaconda interface. This is due to several reasons. But as you pointed out, you may access them via pip installs.
I am asking on behalf of my client. Their analytics platform allows conda-compliant Python library, and request to make available in conda package. Is there any plan for DSWS?
