Python Time Series - Convert Date Index to Pandas Column
Hi All,
In a simple time series, how do you convert the timestamp, which is in an index to a pandas column formated in dateimte?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythontime-series
If you have a dataframe named 'df' with DatetimeIndex, the following command will add a column labeled 'Timestamp' and the values corresponding to the values of the index:
df['Timestamp'] = df.index
E.g.
df = ek.get_timeseries('EUR=','CLOSE')
df.info()
This returns:
<class 'pandas.core.frame.DataFrame'>
DatetimeIndex: 71 entries, 2020-09-28 to 2021-01-04
Data columns (total 2 columns):
 #   Column     Non-Null Count  Dtype
 0   CLOSE      71 non-null     float64
 1   Timestamp  71 non-null     datetime64[ns]
dtypes: datetime64[ns](1), float64(1)
memory usage: 1.7 KB
