RICs return null datasets
I am trying the get the Jumbos of a few markets. The corresponding RICs are given below:
LCO, LCC, LRC
The following Jumbo RICs are consistently returning null values in the dataset:
['LCOF8-H8^1' ,'LCOG8-J8^1' ,'LCOJ8-M8^1', 'LCOM8-Q8^1', 'LCON8-U8^1', 'LCOQ8-V8^1', 'LCOU8-X8^1', 'LCOV8-Z8^1' ,'LCOX8-F9^1' ,'LCOZ8-G9^1', 'LCOF9-H9^1', 'LCOG9-J9^1' ,'LCOH9-K9^1', 'LCOJ9-M9^1', 'LCOK9-N9^1', 'LCOM9-Q9^1', 'LCON9-U9^1']
['LCCH5-K5^1', 'LCCK5-N5^1', 'LCCN5-U5^1', 'LCCU5-Z5^1', 'LCCZ5-H6^1', 'LCCH6-K6^1', 'LCCK6-N6^1' ,'LCCN6-U6^1']
['LRCF5-H5^1', 'LRCH5-K5^1', 'LRCK5-N5^1' ,'LRCN5-U5^1' ,'LRCU5-X5^1', 'LRCX5-F6^1' ,'LRCF6-H6^1' ,'LRCH6-K6^1', 'LRCK6-N6^1', 'LRCN6-U6^1']
I am trying to using the eikon's python API using the following code:
e.get_timeseries(jumbo_rics, start_date='2015-1-1')
I am able to pull the other Jumbos during 2015-20 duration
18k 21 12 20
Hi @varun.divakar
I would not be able to give you the answer on the content availability for either get_data or get_timeseries
But from my observation by using the API, I could see that some instrument has fewer data compared to others.
You will need to contact Refinitiv Content Helpdesk to clarify on this content topic.
18k 21 12 20
Hi @varun.divakar
I checked a few instruments and they do not have the data for the whole period you requested via API.
Also, please review API limitation guideline at https://developers.refinitiv.com/en/api-catalog/eikon/eikon-data-api/documentation
For timeseries interday, you could retrieve up to 3000 records per single API call.
I have investigated this further, and I think the data is missing. I have attached screenshots of the code for only 1 jumbo here below, so there is no chance of hitting the 3000 limitation you have mentioned. This time I have run the code in Reuters Code Creator. Please see that using the both get_data and get_timeseries gives different results. And neither of them have data as such.
18k 21 12 20
Hi @varun.divakar
Thanks for your additional information.
Now I understand that you are trying to compare the data between get_data() with TR.<xxx>PRICE fields and get_timeseries().
I believe that this instrument code does not carry the data on TR.<xxx>PRICE fields.
This forum is not the best place to ask about content questions.
For an authoritative answer to any content questions, the best resource is the Refinitiv Content Helpdesk.
The moderators here do not have deep expertise in every type of content available through Eikon.
The Refinitiv Content Helpdesk can be reached using Contact Us capability in your Eikon application.
I am not comparing the two functions. I am showing with example that you can't get data using either of the two available functions. What I am asking you is for a workaround to get the data for this RIC. If the data is not available then please let me know.
