python api streaming price can't work on pycharm?
Hello there,
I use sample code your tutorial provide to run python eikon api streaming prices function. It works well on jupyter as I separate my code in different cells for streaming_prices.open() & streaming_prices.close() function. It keeps receiving newly updated data during the time I run these two cells.
But, if I run same code in the same script in pycharm, it doesn't work that well. It can only runs for the first refresh function and then the program go into end. I tried some different approach such as adding time.sleep or systems.("pause") while still remains the problem. Do you have any advice on this? thanks!
import eikon as ek
import os
ek.set_app_key('key')
def display_fields_refresh(streaming_prices, instrument_name, fields):
    print("Fields refresh received for", instrument_name, ":", fields)
    print(streaming_prices)
def display_fields_update(streaming_prices, instrument_name, fields):
    print("Fields updated received for", instrument_name, ":", fields)
if __name__ == '__main__':
    streaming_prices = ek.StreamingPrices(
        instruments=['CNH='],
        fields=['SALTIM', 'CF_BID', 'CF_ASK', 'OPEN_PRC', 'CF_HIGH', 'CF_LOW', 'CF_CLOSE', 'VALUE_TS1'],
        on_refresh_refresh=lambda streaming_prices, instrument_name, fields:
        display_fields(streaming_prices, instrument_name, fields),
        on_update=lambda streaming_prices, instrument_name, fields:
    print("start streaming.......")
    #time.sleep(5)
    #os.system('pause')
    #streaming_prices.close()
    print("stop streaming.......")
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonstreaming-prices
Hi @lawrence.chiang
Can you please try replacing your time.sleep() / adding the following after the streaming_prices open()
asyncio.get_event_loop().run_until_complete(asyncio.sleep(120))
OR something like
asyncio.get_event_loop().run_forever()
You will need to import asyncio off course
sorry, correct some code and provide you with the running result as below. thanks
        on_refresh=lambda streaming_prices, instrument_name, fields:
        display_fields_refresh(streaming_prices, instrument_name, fields),
    # time.sleep(5)
    # os.system('pause')
    # streaming_prices.close()
Fields refresh received for CNH= : {'CF_BID': 6.5174, 'CF_ASK': 6.518, 'OPEN_PRC': 6.516, 'CF_HIGH': 6.5327, 'CF_LOW': 6.5116, 'CF_CLOSE': 6.5165, 'VALUE_TS1': '11:05:25'}
<eikon.streaming_session.streamingprices.StreamingPrices object at 0x0000015B722631C8>
Process finished with exit code 0
