LPC fails to start.Could not find the retrieve the IP address of the Protocol Converter process.
LPC fails to start .Have the following error messages in the log file.
Error initializing the HTTPTunnelManager object. Terminating program
treprdp-apiwebsocketsrrto
Hello, found the answer from another post. Issue was server hostname (FQDN), where lPC is installed, was missing from /etc/hosts. So LPC process could not resolve hostname to IP..
Hi @tm
Is this an existing LPC installation + existing appt that has suddenly stopped working or is this a new install and/or new application?
Hi @tm
Also please confirm which version of LPC you are using?
