hi there,
I am trying to run your python example for RTH download, i simply copied the code from:
but i get these error messages below and the output file is empty.
__main__
Login to DSS Server
Send Login request
Token=_qhzRQRkEbfBT14OFnWoq7ndbfndmOEfv5oumyXBZZ8lQpuJLE4alE8XxuTKKDAuG4M1Yr38vM195JP0KyjF8ijzQ6_gNXDS06pyv1vm6bFYnDIK1ZKmTsPIWdiyH-vfroL13n-c0aZsFnXELwi4PKehho9P5jjJlihWTMsK0MDeeRH7Z7YYKFbt9ucFVqC3X0SbmRFj-hG-6LBBJ1_jsmlthmvJsIh9tfiGQm5uadM4FufBbX4xqWihBAyBsTncXQI9ucuRnPN1ZsQs5A4nMq05_gTEI5VZ7OZbb08DUesE
OrderedDict([('ExtractionRequest', OrderedDict([('@odata.type', '#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.TickHistoryTimeAndSalesExtractionRequest'), ('ContentFieldNames', ['Trade - Price', 'Trade - Volume', 'Trade - Exchange Time']), ('IdentifierList', OrderedDict([('@odata.type', '#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.InstrumentIdentifierList'), ('InstrumentIdentifiers', [OrderedDict([('Identifier', 'PEUP.PA'), ('IdentifierType', 'Ric')])])])), ('Condition', OrderedDict([('MessageTimeStampIn', 'GmtUtc'), ('ApplyCorrectionsAndCancellations', 'False'), ('ReportDateRangeType', 'Range'), ('QueryStartDate', '2016-09-29T00:00:00.000Z'), ('QueryEndDate', '2016-09-29T12:00:00.000Z'), ('DisplaySourceRIC', 'True')]))]))])
Status Code=200
Status is completed the JobID is 0x075dda1e01b71e51
Notes:
Extraction Services Version 14.3.42012 (5bce45a491e6), Built Dec 7 2020 18:13:00
User ID: 9027506
Extraction ID: 2000000207049132
Schedule: 0x075dda1e01b71e51 (ID = 0x0000000000000000)
Input List (1 items): (ID = 0x075dda1e01b71e51) Created: 2020-12-16 21:48:59 Last Modified: 2020-12-16 21:48:59
Report Template (3 fields): _OnD_0x075dda1e01b71e51 (ID = 0x075dda1e01d71e51) Created: 2020-12-16 21:48:58 Last Modified: 2020-12-16 21:48:58
Schedule dispatched via message queue (0x075dda1e01b71e51)
Schedule Time: 2020-12-16 21:48:58
Processing started at 2020-12-16 21:48:58
Processing completed successfully at 2020-12-16 21:48:59
Extraction finished at 2020-12-16 21:48:59 UTC, with servers: x04q13
Instrument <RIC,PEUP.PA> expanded to 1 RIC: PEUP.PA.
Total instruments after instrument expansion = 1
Your request was truncated due to your Contract Entitlement
Report suppressed because no instruments are permitted
Retrieve result from https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/RawExtractionResults('0x075dda1e01b71e51')/$value
Write output to ./TestOutput4437.csv.gz completed
