Difference between TR.AccountsReceivableTradeNet vs TR.AcctsReceivTradeNet
I was looking through some files and I found the formula TR.AccountsReceivableTradeNet. the formula I generally use for Accounts Receivables is TR.AcctsReceivTradeNet. I was wondering what is the difference between these 2 formulas because they provide very much different results
eikoneikon-com-api
@varunvinod.mandhana
The field TR.AccountsReceivableTradeNet is not exposed in the current version of the metadata, which you can verify by looking up this field in CodeCreator or Data Item Browser apps in Eikon or in Formula Builder wizard in Eikon Excel. The field TR.AcctsReceivTradeNet on the other hand is there, and we recommend you use the field that is found in the current version of the metadata. This said, in my quick test with a bunch of stocks from around the world I always see both of these fields return the same result. If you have an example where these fields return different results, we can look into it.
