Hi @stepan.kalika,
Can you confirm the version of the API you are using? Also, post the actual code that doesn't respond.
Your version is quite old, you should upgrade to the latest (1.0.0a7.post1) and confirm if you reproduce the issue.
endpoint.send_request(method = rdp.Endpoint.RequestMethod.POST, body_parameters = swap_body)
endpoint_url = "https://api.ppe.refinitiv.com/data/quantitative-analytics/v1/financial-contracts"session = rdp.open_desktop_session(APP_KEY)
endpoint = rdp.Endpoint(session, endpoint_url)
swap_body = {
"outputs": ["Data", "Headers", "MarketData"],
"universe": [
"instrumentType": "Swap",
"instrumentDefinition": {
"tenor": "5Y",
"legs": [
"direction": "Paid",
"notionalAmount": "10000000",
"notionalCcy": "EUR",
"interestType": "Fixed",
"interestPaymentFrequency": "Quarterly",
"interestCalculationMethod": "Dcb_30_360"
"direction": "Received",
"notionalCcy": "JPY",
"interestType": "Float",
"indexResetFrequency": "Quarterly",
"interestCalculationMethod": "Dcb_Actual_360"
"pricingParameters": {
"valuationDate": "2015-06-22"
response = endpoint.send_request(method = rdp.Endpoint.RequestMethod.POST,
thanks, open_platform_session - works well, but if use open_desktop_session - returns error {'code': 401, 'message': 'An invalid location header is received while retrieving RDP access token', 'statusMessage': 'Unauthorized'}
I see that you're sending request to PPE platform.
That means you need to start Eikon with a beta login/pwd.
But as you received Unauthorized status, I assume that Eikon was started with a Prod user account.
