What is required to retrieve bond ratings from TRKD
I'm sending a request as follows for a bond, but am not receiving any rating specific values back. Are there additional fields I need to be using to get bond ratings for S&P, Moody's, and Fitch? I'm sending in RATING and RATING_ID, but do not receive those fields back for any bonds I've tried.
Request:
<Fields>MNEMONIC:OPEN_PRC:CF_LAST:CF_HIGH:CF_LOW:NETCHNG_1:PCTCHNG:ACVOL_1:DSPLY_NAME:RECORDTYPE:RDN_EXCHD2:HST_CLOSE:BID:ASK:YRHIGH:YRLOW:VMA_10D:CF_YIELD:PERATIO:EARNINGS:TRDPRC_1:RATING:RATING_ID:RATING_2:RATING_ID2</Fields>
<RequestKey Name="07330NAL9=" />
Response:
<Fields xmlns="http://www.reuters.com/ns/2006/05/01/webservices/rkd/QuotesCommon">
<F n="DSPLY_NAME">BB&T </F><F n="TRDPRC_1">0.0</F><F n="NETCHNG_1">0.0</F><F n="OPEN_PRC">0.0</F>
<F n="HST_CLOSE">100.0578</F>
rkd-apirkdrequest
We are restricted from using ratings data on TRKD API. Ratings from all agencies are restricted.
Thanks,
Vigil Das
Business Analyst
TRKD API Product Management
If you want all three ratings you need to actually use 3 pairs of Fields not just the two pairs you have defined in your request:
RATING / RATING_ID
RATING_2 / RATING_ID2
RATING_3 / RATING_ID3
When i ran query I received back S&P of A, Moody's of A1 and Fitch of A+ and we have the same Close price.
Have you tried if for a few other corporate bonds and does same thing happen?
I tried for other cusips also none of which returned the ratings. Some were
03232PAB4 and 00826TAH1. I also changed my request to a scope of All instead of List thinking it may return the ratings. I received 121 fields back for the 03232PAB4 cusip but no rating fields.
<ItemRequest ExpandChains="false" Scope="All" xmlns="http://www.reuters.com/ns/2006/05/01/webservices/rkd/Quotes_1">
<RequestKey Name="03232PAB4=" />
Are there settings we need Thomson to setup in order to receive ratings?
I suspect that you will need permission to access the ratings -- has been escalated and will post whatever we find out.
Hi we are investigating on our side (TRKD) and will have an update by tomorrow.
