Eikon Data API: Error code 500
Hi, I have been using the Eikon Data API for more than a year and it worked well until recently. I'm getting the following error message: Error code 500 | Server Error: Internal Server Error - {"code":500,"message":"connect ETIMEDOUT 159.220.40.41:443","statusMessage":"Internal Server Error"}
Can you help me?I have already tried with the IT team to see if there was a problem in proxy, updated the python package.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonerror-500
6.7k 8 6 7
@victor.koyama Hi - I have checked with one of my colleagues and a similar customer issue was resolved by downgrading eikon to previous version (4.0.51). Its probably worth trying this here:
Can you or your IT team try this following the steps below:
1. Close all Office application (except Outlook) and also Eikon processes. You might need to check Task Manager to make sure no Eikon & Office processes running.
2. Open command prompt
3. Go to directory: C:\Program Files (x86)\Thomson Reuters\Eikon (cd C:\Program Files (x86)\Thomson Reuters\Eikon )
4. Enter command line: Eikon.exe –rollback Or silently rollback by using: Eikon.exe –rollbacksilent
5. Wait until Rollback Process terminates in UI or Eikon.exe process disappears from the Task Manager.
After this you also need to stop Eikon automatic updates until we can establish what the issue with Eikon 4.0.52 is.
Then please test your script again.
I hope this can help.
@jason.ramchandani Hello Jason, I tried the rollback approach described above and it does not roll back to version 4.0.51 it only does roll back to either .52 or .53
Refinitiv rollback window says Refinitv Eikon Desktop 4.0.52 has been installed.
I tried rolling back several times, with no avail.
What should I do?
@alexander.yermolayev a similar issue was resolved by:
opening firewall access to:
emea1.apps.cp.thomsonreuters.com 159.220.1.19
amers1.apps.cp.thomsonreuters.com 159.220.40.41
apac1.apps.cp.thomsonreuters.com 159.220.16.215
for the API application. I hope this can help - I posted this to your other question here as well.
6.7k 8 6 7
@victor.koyama Please could you provide the following: Eikon Desktop version, Eikon Library version (ek._version), httpx library version and also nest-asycio library version (you can get these from a pip freeze), also what version of python you are using.
Please can you include the API call code that is failing.
You might try to downgrade httpx library to 0.14.2 (pip install httpx==0.14.2). Also downgrade nest-asnycio to 1.3.3 (pip install nest-aynchio==1.3.3). And try again to see if this helps at all.
If it does not please follow the steps in our detailed troubleshooting guide including enabling the logfiles. This will help to analyse the issue further.
Also have there been any changes to your firewall recently?
The Eikon Desktop version is 4.0.52 (4.0.52055).
How can i find information in eikon library version, httpx library and nest-asycio library version?
The python version i have is 3.7.
I was able to downgrade using the code (pip install httpx==0.14.2) . However for the asycio (pip install nest-aynchio==1.3.3 ) it is giving this response; ERROR: could not find a version that satisfies the requirement. No matching distribution found for nest-aynchio==1.3.3.
It continues with the same error code 500.
There hasnt been any change in the firewall as well.
Thank you
6.7k 8 6 7
Please also check details on this thread - similar issue and it was nest-asyncio. Hence I ask you to do a pip freeze from the command line and tell me the version of both eikon library and nest-asyncio. See my screenshot below:
Please also include the API call that is failing please. I await your response.
6.7k 8 6 7
Please maybe update your version of PIP
(Mac/Unix)
python -m pip install -U pip
Windows
py -m pip install -U pip
You can check the release history for nest-asyncio to confirm 1.3.3 is definitely available.
eikon==1.1.2
nest-asyncio==1.0.0
6.7k 8 6 7
@victor.koyama Ok - better and now please the API call that is failing, Thanks
The API call is the code i am sending from my python? so import eikon as ek?
6.7k 8 6 7
@victor.koyama yes please the API call that is failing ek.get_data or ek.get_timeseries thx
oh ok, it is ek.get_data
6.7k 8 6 7
@victor.koyama yes....please paste the full API call please with instruments, fields and parameters - thx - its the 3rd time i ask.
6.7k 8 6 7
@victor.koyama you also said that you had updated your eikon library - the version here is 1.1.2 - are you running multiple python instances or environments by any chance
return ek.get_data(stock_list,features,{'SDate':first_date.strftime('%Y-%m-%d'), 'EDate':end_date.strftime('%Y-%m-%d'), 'FRQ':'D'})[0]
ek.get_data(stock_list,features,{'Period':item})
oh my bad, i did the update but i did a downgrade on the excel version. what is the code again to update eikon in cmd with the proper version you recommend?
not excel, eikon version
i tried this code as well,
  1. py -m pip install -U pip
appearing this error, do you know what it might be?
6.7k 8 6 7
Look we are going a bit round in circles here - when i say all instruments and fields and parameters i want to see the instrument list and the list of actual fields. I need these to help you. Please post the full API call - i cannot intuit the instruments or fields from a variable name.
First though - can you update your eikon library to 1.1.8. (pip install eikon==1.1.8). Then try the request again. Also then conduct another pip freeze and tell me the versions of httpx, nest-asyncio please.
import pandas as pd
import eikon as ek
import datetime as dt
from datetime import datetime
# ### Functions
# #### Related to main databases
# In[18]:
def get_data_reuters(stock_list, features,first_date, end_date): #Function to retrive data from Reuters API
def working_day(date, increment):
while date.weekday() in (5,6) or date.strftime("%Y-%m-%d") in np_feriados:
date = date + dt.timedelta(days = increment)
return date
def retrieve_database(csv_path, att_data, features): #retrive our database
#Open chosen file
df_file = pd.read_csv(csv_path, index_col = False)
#Find the lastest date
file_date = df_file['date'].iloc[1]
file_date = datetime.strptime(file_date,'%Y-%m-%d').date()
delta_period = (att_date - file_date).days
first_day_month = dt.datetime.today().replace(day=1).date()
first_working_day = working_day(first_day_month, 1)
if att_date == first_working_day: #just update stock list on the first working day of the month
stock_turple = ek.get_data('SCREEN(U(IN(Equity(active,public))/*UNV:Public*/), IN(TR.ExchangeCountryCode,"BR"))','TR.CommonName')
stock_list = list(stock_turple[0]['Instrument'])
stock_list.extend(foreign_ric) #add foreign rics at the beginning of the month
else: #if not the first day of the month, get stocks form file
stock_list = list(df_file.drop_duplicates(['ticker'])['ticker_reuters'].dropna())
#Define the search interval
if file_date < att_date:
first_date = working_day(file_date + dt.timedelta(1),1)
else:
first_date = att_date
end_date = att_date
print("Acessando API Reuters para extração de dados...")
df = get_data_reuters(stock_list,features,first_date, end_date)
return (df, df_file, file_date, stock_list) #Return df with retrieved files, history file and latest history date
def data_cleansing(df_stock, column_pivot, att_date, end_date): #Clean and format the raw data
#Treat the date
df_stock['Date'] = df_stock['Date'].str.slice(start = 0, stop = 10)
#Delete rows with NaN and 0 values for the column pivot
df_stock = df_stock[df_stock[column_pivot].notnull()]
df_stock = df_stock[df_stock[column_pivot] != 0]
#Lowercase columns name. Change the order
columns_order = list(df_stock.columns.copy())
df_stock.columns = map(str.lower,df_stock.columns)
df_stock = df_stock.rename(columns={'instrument':'ticker'})
columns_order[0], columns_order[1] = columns_order[1], columns_order[0]
columns_order[1] = 'ticker'
columns_order.insert(2,'ticker_reuters')
columns_order = list(map(str.lower, columns_order))
# Insert ticker_reuters column to future searches
df_stock['ticker_reuters'] = df_stock['ticker']
df_stock = df_stock[columns_order]
df_stock['ticker'] = df_stock['ticker'].apply(lambda col: col[0:col.find('.')] if (col.find('.') != -1 and col.find('.') != 0) else (col if col.find('.') != 0 else col[1:]))
df_stock = df_stock.sort_values(['date', 'ticker'])
df_stock = df_stock.loc[(df_stock['date'] <= att_date.strftime("%Y-%m-%d")) & (df_stock['date'] >= end_date.strftime("%Y-%m-%d"))]
return df_stock #return treated dataframe
def update_database(csv_path, df_file,df_stock_clean,file_date,att_date, stock_list, features): #append the cleaned dataframe to the history
if file_date != att_date:
df_base = pd.concat([df_file, df_stock_clean], join = 'outer', sort = False) # if updating for the first time, just append
else:
df_file = df_file.drop(df_file[df_file['date']==att_date.strftime("%Y-%m-%d")].index) #otherwise, delete first
df_base = pd.concat([df_file, df_stock_clean], join = 'outer', sort = False) #then append
df_base = df_base.sort_values(['date','ticker'],ascending = False).drop_duplicates(['date','ticker'])
if 'TR.PriceClose' in features: #check for company events for the base_price only
print("Checando eventos de companhias...")
df_base = company_events(df_base,stock_list,features,att_date)
df_base.to_csv(csv_path, index = False)
def company_events(df_file,stock_list,features_price,att_date):
features_price_only = ['TR.PriceClose.Date','TR.PriceClose']
check_date = working_day(att_date - dt.timedelta(days = 1),-1) #get one day before att_date
df_price = get_data_reuters(stock_list,features_price,check_date, check_date) #get prices from check_date
#clean retrieved df
df_price_clean = data_cleansing(df_price,'Price Close', check_date, check_date)
df_price_clean = df_price_clean.loc[df_price_clean['date'] == check_date.strftime("%Y-%m-%d"),:] # API might bring old dates
df_values = df_price_clean[['ticker_reuters','price close']].set_index('ticker_reuters')
df_hist = df_file.loc[df_file['date']== check_date.strftime("%Y-%m-%d")] #get prices of check_date from current base
df_hist = df_hist[['ticker_reuters','price close']].set_index('ticker_reuters')
#check whether prices for check_date are equal in both base_price and reuters
df_compare = pd.concat([df_hist,df_values], join = 'inner', axis = 1, sort = False)
df_compare['compare'] = (df_compare.iloc[:,0].round(decimals = 5) == df_compare.iloc[:,1].round(decimals = 5))
#If they differ, it's due company events
df_stock_event = df_compare[df_compare['compare'] == False].reset_index() #get_stocks where prices differ
stock_event = list(df_stock_event['ticker_reuters'])
if stock_event:
print("Atualizando eventos...")
start_date = df_file['date'].iloc[-1]
#update price history in the base_price for the selected stocks
df_att_hist = ek.get_data(stock_event,features_price, {'SDate':start_date, 'EDate':att_date.strftime("%Y-%m-%d")})[0]
df_att_hist_clean = data_cleansing(df_att_hist,'Price Close', att_date, dt.datetime.strptime(start_date, "%Y-%m-%d"))
df_file = df_file.loc[df_file['ticker_reuters'].isin(stock_event) == False ,:]
df_file = pd.concat([df_file,df_att_hist_clean], ignore_index = True).reset_index().drop(columns='index').sort_values(['date','ticker'], ascending = False)
return df_file #returns the corrected price history
# #### Related to financial database
# In[19]:
def get_data_reuters_financial(csv_path,att_date,features, period): #Retrieve data from eikon API (different years)
else: #if not the first day of the month, get stocks from file
data = []
for item in period:
df = ek.get_data(stock_list,features,{'Period':item})
df[0]['date'] = item[2:6]
data.append(df[0])
return data
def treat_data_financial(reuters_root_data):
for x in range(len(reuters_root_data)): #Build a single df appending data from reuters
if x == 0:
df = reuters_root_data[0]
else:
df = df.append(reuters_root_data[x], ignore_index = 0)
df = df.rename(columns = {'Instrument':'ticker_reuters'})
df.columns = map(str.lower, df.columns)
df['ticker'] = df['ticker_reuters'].apply(lambda col: col[0:col.find('.')] if col.find('.') != -1 else col)
df = df.sort_values(['ticker','date'], ascending = False)
df = df.set_index(['ticker','ticker_reuters','date'])
df = df.dropna(how='all')
df = df.drop_duplicates()
return df
def update_database_financial(path, df_data, year_array,index_col):
df_hist = pd.read_csv(path)
df_hist = df_hist[df_hist['date'].isin(year_array)==False].set_index(index_col) #drop data to be updated
df_data = pd.concat([df_data,df_hist], join = 'outer', sort = False, axis = 0).drop_duplicates()
df_data = df_data.reset_index().sort_values(['ticker','date'], ascending = [True,False]).set_index(index_col)
df_data.to_csv(path)
# ### Set Reuters API Key
# In[20]:
ek.set_app_key('706f7cf0f1d14a1983f54c32c70dd75ee03b308f')
# ### Update Databases
# #### Define all the bases which will be updated
# In[21]:
np_feriados = pd.read_csv('//pfs14/PSI/GESTAO TERCEIROS/Mesa Bolsa/Database/feriados/feriados.csv').to_numpy()
#databases path
path_beta = '//pfs14/PSI/GESTAO TERCEIROS/Mesa Bolsa/Database/dados_acoes/beta_acoes.csv'
path_price = '//pfs14/PSI/GESTAO TERCEIROS/Mesa Bolsa/Database/dados_acoes/preco_acoes.csv'
path_valuation = '//pfs14/PSI/GESTAO TERCEIROS/Mesa Bolsa/Database/dados_acoes/valuation_acoes.csv'
path_starmine = '//pfs14/PSI/GESTAO TERCEIROS/Mesa Bolsa/Database/dados_acoes/starmine_acoes.csv'
path_index = '//pfs14/PSI/GESTAO TERCEIROS/Mesa Bolsa/Database/dados_indice/preco_indice.csv'
path_financial = '//pfs14/PSI/GESTAO TERCEIROS/Mesa Bolsa/Database/dados_acoes/financial_acoes.csv' #different update
#databases feature
features_beta = ['TR.BetaDaily180D.Date','TR.BetaDaily180D','TR.BetaWklyAdj2Y','TR.BetaDaily90D']
features_price = ['TR.PriceClose.Date','TR.PriceClose','TR.Volume','TR.MarketCapLocalCurn']
features_valuation = ['TR.FwdPtoEPSSmartEst.Date','TR.FwdPtoEPSSmartEst','TR.EVtoEBITDASmartEst','TR.CompanySharesOutstanding',
'TR.DPSSmartEst','TR.EPSSMARTEST','TR.EPSActValue','TR.ReturnOnCapitalPercent','TR.EVSmartEst']
features_starmine = ['TR.CreditTextRegRank.Date','TR.CreditTextRegRank', 'TR.ValMoRegionRank','TR.ARM100Region','TR.ARM100RegionChange'
'TR.NumberOfAnalysts','TR.CombinedAlphaRegionRank']
features_financial = ['TR.EBITDAActValue','TR.NetprofitSmartEst','TR.NDebtSmartEst','TR.TotalDebtOutstanding',
'TR.NetprofitActValue','TR.EBITDASmartEst','TR.NetDebtToEBITDA','TR.RevenueActValue',
'TR.RevenueSmartEst','TR.EBITActValue','TR.DepreciationAmortizationActValue','TR.SGandAExpActual',
'TR.OperatingExpActual','TR.GenAdminExpActValue','TR.SellMarkexpActValue','TR.RnDExpActual',
'TR.PreTaxProfitActValue', 'TR.TaxProvisionActValue','TR.CapexActValue','TR.IntExpSmartEst','TR.IntExpActual']
features_index = ['TR.PriceClose.Date','TR.PriceClose','TR.Volume']
index_list = ['.BVSP']
foreign_ric = ['CZZ','GDXJ.K','VALE.K','.STOXX'] #foreign rics to be added at the beginning of every month (when the stock list is updated)
index_col_financial = ['ticker','ticker_reuters','date']
#defining years to be updated in the financial database
next_year = dt.date.today().year +1
year_array = [next_year - i for i in range(0,3)]
period = ['FY'+ str(item) for item in year_array]
path_list = [path_beta, path_price,path_valuation,path_starmine, path_index] #finance and index database must not be added to the list
features_list = [features_beta, features_price, features_valuation,features_starmine, features_index]
column_pivot = ['Daily Beta - 90 Day','Price Close','Company Shares ','Credit Text Mining Region Rank','Volume']
base_list = [None]*len(path_list) #build list with bases' names
index = 0
for item in path_list:
i = -1
while item[i] != "/":
i = i-1
base_list[index] = item[i+1:len(item)]
index = index + 1
# #### Execute the query
# In[22]:
#define dates
att_date = working_day(dt.date.today() - dt.timedelta(days = 1), -1)
print(" ********** Iniciando o processo de atualização das bases **********\n")
print("Número de bases a serem atualizadas: "+ str(len(path_list)+1) + "\n")
index = 0
for path in path_list:
print("Atualizando base " + base_list[index])
(df_stock, df_file, file_date, stock_list) = retrieve_database(path, att_date, features_list[index])
print("Limpando e tratando dados extraídos...")
df_stock_clean = data_cleansing(df_stock,column_pivot[index],att_date, file_date)
print("Salvando base de dados...")
update_database(path, df_file, df_stock_clean, file_date, att_date, stock_list, features_list[index])
print("Base " + base_list[index] + " atualizada! \n")
index = index + 1
#update different procedures - (financial base)
print("Atualizando base financial_acoes.csv")
data_reuters = get_data_reuters_financial(path_financial, att_date, features_financial,period)
df_data = treat_data_financial(data_reuters)
df = update_database_financial(path_financial, df_data, year_array, index_col_financial)
print("Base financial atualizada! \n")
print("**********Processo de Atualização Encerrado!**********")
i will send you the other informations, just a minute
6.7k 8 6 7
After you have installed the latest eikon library - please try the following:
ek.get_data('EUR=','CF_CLOSE')
and send me the result - I just want to see if you have connectivity with a simple call.
do you know why i get this error when i write the code pip install eikon==1.1.8?
6.7k 8 6 7
@victor.koyama im not exactly sure but take a look at this thread
i updated the eikon with the version 1.1.8.
httpx is 0.14.3
nest-asyncio is 1.3.3
regarding the code you sent me to try, here is the error:
6.7k 8 6 7
@victor.koyama OK could you please try the following 4 steps:
  1. Open http://localhost:9000/api/status to check if API Proxy is running.
  2. Verify if Refinitiv server is authorized by your proxy
    Run cmd.exe then type "ping emea1.apps.cp.thomsonreuters.com", you should have following result:
    Reply from 159.220.1.19: bytes=32 time=34ms TTL=242
  3. In your script, activate verbose log and when you set app_key, you can test if connection is up before continue as follow:
  1. ek.set_log_level(1)
    ek.set_app_key('.....')
    state = ek.get_desktop_session().get_open_state()
    if state == ek.Session.State.Open:
  2.     ek.get_news_headlines('R:LHAG.DE', date_from='2019-03-06T09:00:00', date_to='2019-03-06T18:00:00')
4. Lastly, if you can define environment variable HTTPX_LOG_LEVEL=trace then run your script, we'll have full logs to investigate and check what's the root cause of this error code 500.
I guess the refinitiv server is no authorized by my proxy. See picture below:
The second step is bring me an error in the cmd. please, could you confirm?
6.7k 8 6 7
@victor.koyama this is why I asked about changes to firewall. I will email you the Eikon networking guide as it is and also the following instructions for your IT team - you may need to check with them. See main points below:
Please see pages 15-20 for configuring firewall, proxy and internet options in the attached document.
Also on page 14, you will see the IP Subnet and TCP Port that we are using.
Here I will give you a summary of the changes that have to be made on your proxy server and the firewall.
Proxy Server:
Please approve the connection to the following domains (on port 80 and 443)
*.cp.extranet.thomsonreuters.biz
*.refinitiv.biz
*.thomsonreuters.net
*.refinitiv.net
Firewall and Antivirus:
Please also make sure that the firewall and antivirus allows the following processes:
Eikon.exe (Thomson Reuters Eikon Desktop)
EikonBox.exe (Thomson Reuters Eikon, Interactive Map Component)
EikonDM.exe (Thomson Reuters Eikon Deployment / Update Manager)
TRUserServiceHostv4.exe (Thomson Reuters Common Office User Service Daemon)
Excel.exe (Thomson Reuters Eikon Excel)
EikonSupportTool.exe (Eikon Support Tool)
Please make sure that the firewall server allows you to download EXE files from the following domains (on port 80 and 443):
*.refinitiv.biz
*.refinitiv.net
HTTPS Tunneling
Thomson Reuters Eikon uses HTTPS Tunneling to connect to Thomson Reuters Eikon platform for Streaming Service. In some Proxy Server, HTTP/HTTPS Tunneling is disabled by default because of unknown protocol e.g. Web Sense. Meanwhile some Proxy Servers are able to set up a rule to enable or disable it.
It is necessary that customers set up a rule to ALLOW HTTPS Tunneling to the following URL:
*.refinitiv.biz
*.refinitiv.net
You may also need to allow our domains if you are implementing SSL/TLS decryption or inspection as this might break the certificate from our servers and will break the connection to the Eikon Desktop application.
*.refinitiv.biz
*.refinitiv.net
Hello @jason.ramchandani
Thank you for the detailed information. Has this change been made recently? I am experiencing the same issue as Victor. All my EDAPI scripts used to work fine and now they are getting blocked. When were these the changes in domain usage implemented and why weren't users informed of these changes in advance?
Many thanks.
6.7k 8 6 7
@victor.koyama As an outside chance can you please can you also try:
1. Clean Eikon cache. From Windows menu Thomson Reuters ==> Clear Cache
2. Reboot the machine then retry API call.
Hi, sorry for the late response. The IT team was looking into this matter. What they told me was that there is no problem with the proxy, but problem is with the reuters server. We cant connect into the reuters server in this route: 159.220.40.41:443 . Please, could you verify if this server is working or it was changed/updated? How can i proceed with this matter?
Also i tried clearing the cache, but the problem still persists.
Thank you!
