bid_yield get_snapshot API request.
Hello, I'm pulling down ask_yield and bid_yield via the API and I'm seeing different values in the API call result then what's shown in the Eikon UI.
Symbol: US927804FG41 For Bid Yield the UI is showing 2.8770 but the API result is 2.89
This is my API call: df = streaming_prices.get_snapshot( instruments = rics, fields = ['BID_YIELD', 'ASK_YIELD'] )
Can you please advise on the field/request needed to pull down 2.8770? I believe 2.8770 is RT_YIELD_1 is that field available in the get_snapshot request?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonyield
18k 21 12 20
Hi @mschweig
The RIC code for 'US927804FG41' is '927804FG4='
You can try this code to get the RIC code:
df,e = ek.get_data('US927804FG41','TR.RIC')
df
On the Eikon Desktop, please launch a Quote application and open '927804FG4=' RIC code.
Then click display all fields to see all the field names that can be used with streaming_prices.
On the quote application, you can hover mouse pointer to see the field names.
I believe in this case, you should use RT_YIELD_1 field.
For an authoritative answer to any content questions, the best resource is the Refinitiv Content Helpdesk.
This forum is dedicated to things specific to the use of Eikon APIs.
The moderators here do not have deep expertise in every type of content available through Eikon.
The Refinitiv Content Helpdesk can be reached using Contact Us capability in your Eikon application.
